Randy
My newly purchased 84 C-27 with the Universal M-18 (14hp)diesel will cruise easily at 2000rpm. But, when the throttle is pushed all the way forward, the engine revs increase to about 2300rpm, but no more. Shouldn't this engine be capable of 2500-2800rpm, assuming the prop is correct?I believe that the prop is correctly sized based on the recommendation of Catalina/Universal, though now that the boat is in the water, I can't check the prop. For what it's worth, when pushing the throttle forward, it felt as though the engine was held back by lack of throttle travel, as opposed to the prop. i.e. it pulled strongly right up to 2300rpm. Also, there is minimal soot on the transom, so I'm not thinking the engine is grossly overloaded by the wrong prop.Any ideas or suggestions?
