Ted Reed
1978 O'Day 37 with rear cabin. It has the 3-cylinder Yanmar engine that is raw water cooled (why would anybody do that?). I re-worked the exhaust manifold (as it was leaking) and noticed the metal was very soft on the inside: you could almost scrape the mushy metal with your fingernail--probably not a good sign! Which makes one question the integrity of the rest of the engine. Now I notice oil leaking on the rear of the engine, between the block and head. I'm guessing this engine has lived it's life!The question: How does this engine come out of the boat? Coincidentally, a marina neighbor also has the same boat, and he cut a hole in the cockpit floor not too long ago, because he thought he was going to replace the Yanmar. Turns out he didn't, but boy, does he have access! (He built a "hatch cover" out of the piece he cut out.) Seems like a great idea, but, what does this do to the integrity of the boat? Has anybody else done this? Is there some other way, short of dismantling the old engine inside and re-assembling the new one back inside?Thanks in advance!
