Engine power reduction.
Clydo
May 28, 2013
366
Catalina C310 SF Bay/Delta
I second this. I was experiencing the same issues with mine and replaced the fuel pump (after countless filter changes and exploring other possible causes).....zero issues since replacing the pump 2 years ago. Oh, and I got the pump from NAPA.
How old was your lift pump? Be interesting to know how long they last. Of course eng hours are a
factor.
Clyde Thorington
C310 # 245
I LEAN TOO
San Jose, CA
Oct 17, 2011
221
Catalina 310 USA
pro
factor.
Clyde Thorington
C310 # 245
I LEAN TOO
San Jose, CA
probably original (2001), with 400 hrs on it.
Nov 16, 2012
1,055
2000 C310 with 2K hours on the engine. It was replaced by the PO just before we bought the boat last year. But I'm not sure if it was the original pump he replaced...
Nov 18, 2010
2,441
Catalina 310 Hingham, MA
Did you solve problem by (1) cleaning tank (2) replace fuel filter (3) replace lift pump or all of the above?
Thanks for your comments.
Clyde Thorington
C310 #245
ILEAN TOO
San Jose, CA
I did 3. I have replaced the lift pump twice in the last year. I bought several cheap ones from amazon to have as backup. They work but don't seem to last as long. Although in fairness I have done about 1000 hours on the engine traveling about 7000 nm with a lot of that motoring or motor sailing.
Tom J
Sep 30, 2008
2,325
Catalina 310 Quincy, MA
Might be a good idea to get your fuel polished, Clyde. A good mobile polishing service will come to the boat and run the fuel through their machine several times, until it tests clean. Typically, any diesel system with a number of years and low hours will have some growth in the fuel. A bouncy ride is all it takes to stir up the gunk, and loss of power is the first sign of trouble.
