On my Perkins 4.154 the salt water pump output is for a 1" hose. The heat exchanger rubber inlet fitting is 7/8". Currently there is a 7/8" custom copper tube that is flared out to the 1" hose. According to TransAtlantic there isn't a 1" rubber fitting for the Bowman heat exchanger.
I cannot find 7/8" hose barb fittings. I also cannot easily find someone to fab a flared end for a 7/8" copper tube.
I don't really want the copper since it's saltwater but that is what is on there currently and I don't see another solution. IF I can find a person to fab the copper tube to flare from 7/8" to 1", I'll keep 3 aboard and monitor the part for regular replacement.
Any ideas?
Any ideas?
