1984 Catalina 30, Westerbeke 25XP diesel. New boat to me, on the hard running on hose to salt water intake, no load. When boat idles it runs hot, up to 190-200, I won't see how hot it will get. Push up to 15k RPM's and temp drops to normal. Had water heater that is still plumbed with engine coolant, leak in tank on sink water side so bypassed. There is a valve diverting coolant to hot water tank, when valve is closed, pushing water through water heater, it overheats at idle and runs 160ish at 15K rpm's. When water heater diverter valve is open, allowing direct flow through heat exchanger, it runs 160ish at idle and 140ish at higher rpm's.
Heat exchanger just serviced and tested, 160 degree thermostat, functioned properly in pot of water with meat thermometer. Engine starts easily with pre heat and runs smooth (no load) minimal smoke at start up. Engine running temp spec is 165-195. Fairly new fresh water pump. Makes good water of of stern (there is some pressure from hose). Have not tested gauge but is very consistent with symptoms.
Any insight? Experience with similar situations?
