Bill Dorsey
I have had an of and on problem with my Yanmar 2GM20F overheating. It first happened while in a long line of boats waiting for a bridge to open. The overheating buzzer came on. After a cooldown I saw that the fresh water was low and a lot of water was in the resevour. I put the water from the resevour back in the engine heat exchanger and proceeded without any further problems. Since then I have cleaned the heat exchanger, replaced the fresh water cap, and checked the resevour system for leaks. None of these have worked. I still get overheating when I idle for a long time, and I always have to return the fresh water from the resevour to the heat exchanger after each day of motoring. Just recently, I had this problem occur near the end of a long day of motoring into a heavy sea and wind. Again the resevour was full and after returning the water to the heat exchanger, I proceed with out further trouble. Any thoughts on this problem would be appreciated.
