mechanic
Bill,I would buy Yanmar's service manual if you're determined to replace the head gasket yourself. My advice to you is to not take how-to advice from the well-intentioned folks here regarding the procedure on head gasket replacement. The wrong advice could cost you the motor. I don't know how much of a 'motor-head' you are, but you will need a high-quality torque wrench, and one that will fit in the confined space of the motor compartment. (The motor head is supposed to be re-torqued every two years anyway - according to my Yanmar mechanic - so it will come in handy in the future)I have done several engine tear-downs of the ordinary street variety, and if it were me, I would most likely farm the head gasket job out to an experienced Yanmar mechanic. Those little Yanmar motors are so expensive to replace....I would be inclined not to take the risk of wrecking it. If you do decide to take that job on yourself, think about whether or not you will need to have the head machined - it may be warped. A warped head might be the cause of your blown gasket. And putting a warped head back on with a brand new gasket will be ineffective to say the least. And I confess I speak from painful experience..... Good luck if you decide to forge ahead. Mike
