Oil Gets Past Rings?
I've heard this many times that overfilling the engine (diesel) can cause a runaway - but I've never experienced it, fortunately.I don't know the mechanics of this but I would suspect the oil would have to get past the rings. Oil, being a heavier fuel, will cause the engine to burn slightly hotter than diesel.It probably wouldn't take very much oil, either, as the engine speed is regulated by the quantity of fuel going into the injectors. If any more fuel, i.e., oil, is added/introduced then the engine would run faster. This, then, becomes a vicious cycle (no pun intended) and you have your "runaway".Just about the only way to stop a runaway is by shutting off the air flow. Technically one might be able to stop it by shutting off the fuel flow but all the fuel in the line would probably have to be consumed - and - if oil is getting into the combustion chambers, the oil would have to get used up too. *yksThis might take a while but then the oil might cause the head gasket to go or perhaps something else - head? Crank? rod? *yks (again).My preferred method to stop a runaway would be to use a shoe, tong, sandle or the like over the air intake. Something that has a bit of roughness to the surface that would allow a "bit" of air to go past but not shut it off completely all at once. While a soft material like a towle, or so, would work, realize that there are several pounds of pistons, crankshaft, and flywheel turning at way past readline RPMs and the inertia of stopping all this spinning iron will really suck "whatever" in really FAST.I've dealt with a runaway that was next to me and it wasn't fun. The couple were about ready to jump ship. Oh, by the way, it will pour out "tons" of black smoke while it's "running away"!The water up here is so cold that jumping ship may be actually worse than staying on board!
