Engine O'haul + Motor Mounts?
Nov 17, 2012
86
Hunter 37.5 Cherubini Bayfield, WI
It has been 3 weeks and about 20 hours of motoring of my 1980 Cherubini 37.5 since the engine was completely stripped down to the block and restored. Yesterday it began to rattle loudly, especially in gear under a load.
I called the marina manager who arranged the haul-out, he sent the technician who had hauled and reinstalled the motor to my boat, we took it out for a drive where he announced "you need new motor mounts" (@$1000+ for P&L).
Shouldn't he have asked me if I wanted the motor mounts replaced while the motor (Yanmar 3 cyl) was out of the boat?
He never did.
Now he want's to replace them for me @ $500 parts + 5-6 hours of labor. The motor itself is otherwise "like new". I thought I was investing in an otherwise very nice Cherubini 37.5, for a future of pleasant cruising. Again:
Feb 11, 2006
141
Hunter 34 Galveston,Texas
Maybe they never took mounts out of boat.Or were they attached to engine on removal? Did they look collapsed before removal? More than likely they just removed the nuts from the mounts and lifted engine out. Most people don't pay attention to detail.It is unfortunate.
You are not going to get a break on the price.Just do it yourself .
It's not that hard.You will have to re-align the engine after/during. That will be rewarding.
It should not take 5 or 6 hrs.
Feb 8, 2014
1,300
Columbia 36 Muskegon
And shop around for the mounts. You can probably get them much cheaper than you were quoted. They are not specific to the engine, many different brands will work. Just need the same height and similar weight / hp rating.
Dec 2, 1999
15,184
I would be very careful with aftermarket motor mounts. Most of the Yarmar mounts are specific to a position. If not installed in those position there can. Be sever shaking
Not long enough to have all of the answers. 'Couple decades.
The reason I asked is that if boating was new to you, then there could be a small case made that the mechanic should have asked.
You are not the first (nor the last) skipper to say: "Heck, while I was in there, I shoulda..."
Shoulda, woulda, coulda...:confused:
You know the drill. :)
Johnb
Hunter 37-cutter Richmond CA
I figure the best and most conscientious would have looked at the total installation, including stern tube, mounts, exhaust, muffler etc and advised if there was anything else that should be should be done as part of leaving you with a rig that would be as trouble free as possible for as long as possible. That is what the best quality service people do.
The owner's responsibility is to know good advice when they hear it.
MitchM
Jan 20, 2005
1,031
yanmar mounts are indeed 2 different stiffnesses for front vs. rear. the mounts can be adjusted to a certain extent using the adjustment nuts. but if they are 'bottomed out' they must be replaced. unfortunately, by the time this bottom-out happens, the alignment of the prop shaft at the coupler may have been a adversely affected. did your tech check for allowable face out at the prop shaft coupler before s/he sent you on your way ? have this done by an experienced mechanic--whom i suspect is not the person who last worked on your boat.
Nov 17, 2012
86
I'm keeping the "who" to myself... so far.
LATEST UPDATE: Called another marine service dealer in area, told my story to him, 'said he'd have someone look at it.
He called me back the same day and said his engine man found the motor mount bolts were all loose, tightened them up and the noise went away. I haven't seen it in person, boat is 3.5 hours away, will be there Tuesday.
Nov 17, 2012
86
OK the tightening of the motor mount bolts seems to have quieted the motors set-in location, however, the porp shaft is definitely out of balance and vibrates quite loudly in forward, low - medium rpm, less-so at full throttle. The tech I am working with now is going to align it this week (I am not there now). He said it would involve loosening the mounts and using a feeler gauge. I am hopeful.
Nov 17, 2012
86
Cutlass Bearing
The current technician said the results of trying to align the prop shaft are: (without hauling-out BUT with motoring about) that it's probably the cutlass bearing causing the vibration noise, which gets less as the rpm's go up. 'Says I maybe could wait 'til haul-out, but do I want to risk motoring around with this condition?
May 17, 2014
136
hunter 380 Plano, TX
Sounds like the same problem I had last year. At low rpm it sounded like the engine was going to throw a rod. We got to checking the mounts while the engine was idling in forward tied up. She was just a bangin and I stepped on the tranny it went quiet. Think I paid $400 for new mounts and alignment and only took a few hours
Jul 27, 2013
298
Hunter 37.5 1065 Rock Hall, MD
Can you tell us which yard did this work? In my opinion, some yards treat boat owners terribly. There is a presumption that we have unlimited dollars and the work is done sloppily and incompletely.
As consumers, we absolutely have the right to share good and bad experiences. I also feel as though there is no effort to be thorough, just to take as much money as possible from the boat owner.
Unfortunately, I don't have the time I would love to have to fix stuff on my boat so I am hostage, in a sense, to having someone else do engine work, refridge work, etc. My experience has been similar.
Therefore, we should start communicating and avoid yards that are no good and patronize those that do good work. Let's make a list, and publish it for all to see. Put market pressure on the boat yards.
Ben
May 17, 2014
136
Ben
I think that is a great idea. While a yard is there to do everything they can and maximize their profit, often there are a lot of things we can and should do or at least participate in. Ask around, check craigslist, check a bar by the docks. Find the guy that knows boats and you show up with him. The yard can't keep you and a friend from working on your boat. This is what I did.
It sounds like the OPs' schedule is busy and like me it is hard to find the time to work on our own boats. Since it is our (wife) plan to go cruising in a few years, I am enjoying upgrading our boat and learning the systems so we will be prepared when the inevitable breakdown occurs away from the dock.
Aug 2, 2009
651
Catalina 315 Muskegon
Thanks to the anonymity of the internet, I can tell it like it is.
The mechanic was a jerk, and you were a dope. Now, I mean "dope" in a nice way, the same way I was a dope on any number of projects where I gained experience the hard way.
In this situation, I'm putting the blame mostly on you, as I cannot get to the point where I can imagine telling a marine mechanic to put the new engine right where the old one is, and then go about my other business as I wait for him to complete the project.
Of course, he should have suggested new mounts. As much as I'd like to blame the mechanic for not looking at the whole picture, I know it would be like blaming my cat for not running to the fridge to get me a beer. It's not what they do.
In the real world, even if you have the mechanic with glowing reviews, they have to be supervised. Of course YOU should have addressed the mounts issue before repairs commenced. And as others have already mentioned, you should have addressed the entire system (filters, shaft, exhaust, cooling, transmission, stuffing box, and fuel tank).
I can tell you with great certainty, that even with four decades of boating experience, and despite having rebuilt a few engines from the crank up with my own two hands, for a project as big as that, I would have asked for advice from this site and at least one other. I look at my boating experience as the years before the internet, and the years after the internet. With just a few keystrokes I can tap into the wisdom of others from around the globe.
That said, and even though the mechanic was acting within the norm for his species, I'd be hesitant to use him again. If I can't find the best mechanic, I can at least avoid the worst.
Nov 17, 2012
86
New Update, Better Days
I am fortunate to be located in a marina, Port Superior, Bayfield, WI, that has slip-ownership and a board of directors made up of these people. Because of this, I believe the maintenance crew here really make an effort to please, 'wish I'd had them do the work from the get-go. I'd gone outside from some bad advise, oh well. The current crew have made reasonable effort to get this buttoned up and I feel they are competent. They re-aligned the motor and it is much quieter. Think I need a cutlass bearing but will wait for haul-out.
I am a casual sailor and not a ship-fitter, a former PHRF keelboat club racer and damn-good trimmer & navigator. Now-a-days my new wife and I love to sail out to any one of about twenty islands within 20 miles of our marina. Spectacular scenery, plenty of safe anchorage to choose, spend some nights out and return home. No plans for voyaging here, just want safe-passage. I will tinker with my boat, we did a lot of improvements to it, and will continue to.
Calm seas ahead, all my best to all who contributed.
JHoward s/v Unity
