The engine is not charging the batteries (two 4D's) very well, as opposed to not-at-all. After tightening the alternator belt, I motored for about 4 hours on the Chesapeake Bay (no wind and was in a hurry), the voltmeter only read 12.4 volts at the end of the trip. It had risen to that level from 12.0 volts at the beginning of the trip. Later, after connecting to shore power, the charge went up to 12.8 volts (Xantrex Freedom 20 inverter/charger). The generator will also raise the charge to 12.8 volts. So, any thoughts as to poor performance when using engine only (in contrast to a situation where there is zero performance)? Volt regulator? Alternator? Connections? Etc. All equipment is 10 years old.
Thanks in advance.
A few probable issues:
#1 You are discharging your batteries far too deeply, don't let them drop below 12.0V!
#2 You could have a battery with a dead short sucking the bank down
#3 You have a bad connection somewhere causing serious voltage drop
#4 You have an erroneous volt meter
#5 You have a diode battery isolator creating excessive voltage drops plus you are overly discharging your bank.
#6 You have two bad charge sources simultaneously. (quite unlikely)
Under normal average house loads (+/- 7-10A), on a 40+/- footer, you should not allow your bank voltage to go below 12.0V when discharging.
The more info you can give us the better. Beg borrow or steal a DC clamp meter and physically measure the alternator output and charger output in amps as well as measuring for voltage drop. Course if you have a battery monitor that would give you the info too.
