Yamar Shock Mounts
I am not a Yanmar engineer so I cannot give you a complete answer. I can provide some information that relates to your question.The Yanmar flexible engine mount is designed to make the vibration transmission rate (engine amplitude rate) small in the engine's operational range. The idea is to reduce hull vibration to a maximum 80db level. This is the same level of vibration present in a passenger car.At the resonance point, which is encountered at both engine starting, low rpms and stopping, the amplitude may be large, but the mode of vibrations as such times is rolling, centered around the propeller shaft(engine dancing around). The upper part of the engine may be vibrated to a certain degree, but there is almost no vibration transmitted to the propeller.The torque specs are determined as in standard engineering practices. They need to be tight enough to prevent predetermined engine vibration and resonance from loosening the fasteners during working loads, but not so tight as to over stress the fastener and create failure. The shock mount values are determined by the elasticity of the rubber. That varies in each different mount. The loading of the rubber determines where the propeller will exit the hull centered in the shaft log. The design of the hull and the engine weight distribution during operation will determine the size of the shock mount. I deal with these engines on a daily basis from those in warranty to those that have been around for many years. One can violate every Yanmar recommendation in the books and the engine will operate. The final determination - How soon will one have a premature failure or have to overhaul as opposed to the projected normal life of the engine? Professionals follow the books and specs. Engineers have designed the engine and provided the information that will provide the longest life for their product. They are not sales people and they haven't any idea of retail sales prices for replacement parts.
