Engine mounts for 2001 B361 Westerbeke 30B 3
Guan
Jul 18, 2011
138
Beneteau Oceanis 361 Vancouver
Hello,
I need to replace engine mounts in my 2001 Westerbeke 30B3 (in the B361).
Only problem is getting the correct ones ,as had to return twice to Westerbeke(items in catalog doesn't fit,) and Beneteau Ward's Info's was not too clear.
Has anyine replaced them?
Can one use non Westerbeke mounts? Much problems in mounting and alignments?
Thanks again.
Guan
Guan
Jul 18, 2011
138
Ok thanks but need correct mount parts number to order the correct mounts.
Beneteau 343 Saint Helens, Oregon OR
Take pictures of your existing. Measure mounting bolt size and spacing. Measure adjustment bolt diameter and approximate length. You can likely find non OEM parts that will work. Even OEM may require those dimensions to confirm.
Mar 15, 2013
197
Islander 32 mkll Comox Hrb.
Find out who sells engine mounts in Van. Guan, and don't buy them from Westerbeke unless you want to pay ten times what they're worth!
