Engine Mount replacement
Steve Miller
I have to replace one of the forward engine mounts for my Yanmar 2QM. Has anyone done this recently? Is it difficult? Any tips, or comments would be appreciated.
Sam Lust
Mount work
I replaced the mounts on the 2GM on my 33 last winter and it wasn't all that tough. I have to figure the QM is similar to the GM. I did them one at a time,un-bolting the mount bracket from the block and removing the mount and bracket as an assembly. Assemble the new mount to the bracket and "reassemble in reverse order of disassembly". Then re-align the engine to the shaft. Not realy that tough either, just a bit tedious and time and back consuming.
Bob G.
To Sam Lust/H33 engine mounts
What brand of mounts did you use on your 2QM and where did you purchase them?
