		Bob
I stated on a previous thread that I thought the zincs were bad because of what the diver told me. This turned out not to be the cause of the knocking. A mechanic told me that one of the injectors is not working properly. This could be true, however, when the engine is in neutral and brought up to 3,000 rpms there is no noise. Once I put it in gear and apply throttle the knocking starts. The engine does not appear to be out of alignment with the shaft and I have not hit anything. This knocking started on its own. Any thoughts or similar experiences?
Thank you.
								Thank you.
