Bruce
Why not flush the raw water cooling systems of diesels? A book showed a flush system through the galley sink with a Y valve tee'd into the raw water intake. You closed the seacock, filled the sink,opened the Y valve, started the engine and pumped fresh water through to reduce corrosion.On our Catalina 36MKII it is ugly to get from the galley drain to the engine intake. This could be done from a fresh water tank line but what kind of valving is needed? Want to avoid contamination of the water tank and would like to keep the installation simple since the valves are located under berths etc. Any ideas? Many Thanks.
