Robin
WARNING- According to a yanmar parts dealer he exhaust elbow on yanmar engines is "disposable" and lasts approximately 3-5 years. Of course one must learn this kind of thing the hard way... After doing some engine work requiring disconnection of the high pressure fuel pipe while trying to bleed the lines a friend releases the compression on the aft cylinder and sea water immediately comes pouring out of the air intake. It took a few days to figure out what was going on. Apparently the air exhaust and sea water join at the mixing elbow and are pumped out together. Inside the elbow they are divided by a steel (not stainless) divider. Apparently the divider had rusted through allowing the water to back up through the air exhaust which is run below the water exhaust allowing gravity or any other simple forces to completely ruin your engine. My elbow looked fine from the outside. If I were you, I would remove the elbow and attached air exhaust piece attaching it to the block(attached by only 4 bolts) and examine it. If there is severe corrosion inside, I would replace it. Part cost me 170 which I would pay with a smile if I were not facing a total rebuild. I never had any trouble at all with my engine prior to this, It must be a freak incident but could easily happen to anyone else out there.
