engine cutoff on O'Day 34/35
13
Oday 34 Fort Lauderdale
I have an 81 O'Day 34 with the Universal Atomic M-25XP. It has a pull cable run from the fuel shutoff through a hole in the side of the port lazerette so it comes out near the engine controls.
I'm guessing this is a modification by a previous owner. Can anyone with a 34/35 tell me how you turn off your engine? If possible I'd like to return it to the factory design, because the pull cable is difficult to operate, gets in the way and is a real ankle buster.
Any thoughts or suggestions welcome. I have the original engine manual, but it doesn't go into anything about how O'Day installed it or the controls.
Chris
May 26, 2004
168
- - Oriental, NC
Through engine control panel
Chris
On my O'Day 35 it is routed through the center of the engine control panel. Make sure you give it generous bend radii or it will be real hard to pull. This the original position.
Goodwinds
DaveM
May 30, 2006
354
Oday 34 Chesapeake Bay
Dunno if you'll be able to get her back to factory spec, my 1981 O'Day 34 is fitted with the Universal 5424. Perhaps your has been re-powered.
None the less, to stop Karma's engine I pull back on the throttle till the engine stops. The throttle has a stop position, which is spring-loaded so that releasing the throttle returns it back to idle.
Oct 7, 2008
379
Oday Oday 35 Chesapeake Bay
My Oday 35 (1985) has a Universal 25M which is 21 horse power deisel. The shut off is a pull handle on 1/4" round metal rod located on the engine control panel. Its probably connected to a cable that shuts off air flow to the engine.
