H
Harry Gafney
1. Yanmar diesel vibrates excessivelyat lowest idle, but not at higher RPM's. Have been told I have to replace engine mounts? Do I? Motor mounts were stretched when a rope entangled around propeller shaft between the prop and the shaft support. Has any one changed the motor mounts on an 18 hp, fresh water cooled Yanmar diesel? Can it be done without removing engine?2. Whenever I turn on the key, the red indicator light on the far right of the engine control panel in the cockpit comes on, but quickly goes out when the engine comes on. According to the literature I have it indicates low pressure. Low pressure what? 3. The engine control panel in the cockpit has to be replaced. Who is manufacturer, and where can I get a replacement? Looking forward to your replys and thanks for your help.
