Engine compartment sound/deadening material
McZube
Apr 5, 2012
119
Hunter 31 Chesapeake Bay, MD
Surveyor says replace it. What can I replace it with that will be effective but suitable for that environment? 1984 Hunter 31 with 2 cyl. Yanmar deisel
Thanks
464
Catalina 30 MKIII Varuna Boat Club
Hi,
I don't know if this is made by the same company, as mentioned in Stu's post, but I just recently replaced my worn, tired and sagging soundproofing with DYNAMAT peel and stick. It took a little cut-n-fit to get most of the areas covered and the metallic tape worked very well on the seams. There is a marked difference in engine noise. So, as far as I am concerned, it is worth the effort and cost.
Happy Sailing
Thanks
Jun 1, 2004
412
Catalina 22 Victoria BC
rpell46 said:
Hi,
Happy Sailing
I'm going to use Dynamat as well. Cost is a major factor as the foam sheets are hellish expensive here and think the Dynamat will provide more dampening per dollar.
Just my two cents.
