I am having issues with the cable that changes gears. The shift lever starting sticking, and now has failed completely. I can shift from neutral to reverse, but I cannot go into forward. I've disconnected the cable from the transmission, and I can shift gears with no problem. The funny thing is the cable seems to be about an inch to an inch and a half short. I'm not sure if the cable just sticks at a certain point or what. Has anyone had this issue and replaced the cable? If so where did you get the cable, and is there any trick to hooking up the new cable? The end of the cable that hooks up to the transmission is spring loaded, so I'm not sure how this thing works. I can find no documentation on this either in the Hunter manuals or the Yanmar manual.
Thanks for any help,
Rick
Rick
