Tony
I have a Yanmar 4JH3E 56hp engine I am not getting the air out of after changing Racor and engine fuel filter.On top of Racor I have the one with a pump in it . What is the correct bleeding point. There is a white plastic slotted nut on the top and on the side is a hex brass nut. does one or both of these need to be pumped clear of air ? There is a bleed nut on top of engine fuel filter, where is the bleed nut on the injector pump ? I have never had a problem before but just can't seem to get this one right to get enginr stsrted.
