Engine Bed
C
Chris
The bolts that hold the engine bed to the boat are loose. On the port side their is an access cover that exposes the nuts. On the starboard side I do not see any access and the nuts are turning behind the fiberglass. Has anyone run into this problem and if so how did you fix it?
E
Ed
34 Engine bed
My 34 has lag bolts which became loose Replaced them with slightly larger. Would much rather have bolted beds
