Engine Alarm
65
Hunter H49 la romana dominican republic
Hello.
I have a Hunter 49 2009 with a Yanmar 4JH4-HTE and Mas-Technologies M200 monitoring System.
Two weeks ago I received an alarm on the M200 about the alternator not working.
I took the alternator out and tested, it was OK and put it back in.
I cleared the events on the M200 on the engine pannel.
NO new Alarms and diagnoses are clear of any new event.
Ran the engine for about 5 minutes to see if water temp rises.
Generation is OK, rpm OK, water temp OK, oil pressure OK, cooling salt water coming out the exhaust OK, fire extintor on engine OK (green).
I STILL have this beep (alarm sound) out of the pannel. I tried the water alarm switch, is sounded louder and when I killed the switch but the other beep continued.
What is this beep for?
When I turn the switch on before starting the engine, the loud beep that checks goes on once and stops like it should and the other beep (the one in question) does not start until I start the engine.
Any help?
Miguel
KD3PC
1,069
boatless rainbow Callao, VA
network alarm sounds like ...if no alarms are present in the alarm/diag display...
some sensor that is configured, is not responding to the health ping...
diags, then a good visual check or vice versa...
Apr 12, 2007
65
Thanks, how do I check for diags?
Where can I find what sensors are configured?
Regards
Miguel
