Engine Alarm Very Faint
1
Hunter 340 Midland, ON
The engine alarm sound is very faint. Does it need replacing and if so any idea where to get the part?
Jun 4, 2004
834
Hunter 340 Forked River, NJ
Before replacing the parts, take off instrument panel mounted on the side of the pedestal and clean up the black ground wire contact points, then the contacts on as many other wires as you can.
Apr 15, 2011
22
Hunter 34 Lake Ouachita
Also check the sensor where it connects to the engine as well, might be a loose connection there or a bad sensor.
May 24, 2004
7,174
CC 30 South Florida
If you need a replacement buzzer check the "archives" as someone had found a reasonobly priced replacement as the Yanmar part is around $130.
Nov 28, 2009
495
Catalina 30 St. Croix
Most Yanmar panels are mounted so that water hits the alarm. Eventually you hear it go off even though there is nothing wrong. I installed a NAPA generic alarm in the back of the panel and disconnected the original but left it in place for looks only. It was much louder than the original and could be heard even from below. It cost $25.00 at the time. Can always get one at a wreck yard for next to nothing.
Jul 29, 2004
413
Hunter 340 Lake Lanier, GA
Linda, I agree with John about first checking the connections, but if you have to replace the buzzer, pull the panel and check the buzzer for the manufacturer and part number. On our 1999 H340, we have a Seaward panel, not a Yanmar panel. See the top picture at this link.
http://www.seawardproducts.com/panels_hunter.htm
If this is the panel you have, the buzzer part is BRP4535S-24-CD, and available from Allied Electronics for about 1/2 the price of what Seaward wanted. It was simple to replace, just don't overtighten the screws when you replace the panel, as it will crack.
http://www.alliedelec.com/search/productdetail.aspx?SKU=70115827
