Ropes End
Scottie,If the "coolant goes flying everywhere" is from the raw water side after the exchanger then I would bet it is the exhaust elbow. When the same thing happened to me it was because the raw water from the exchanger was being blocked at the elbow. The pressure would build up, the alarm would go off because of insufficient flow through the system, and finally the hose between the exchanger and the elbow would blow off resulting in lots of raw water spraying all over the engine. This generally hapens when running at 2500 + rpms for 1/2 hr or longer. You can run at low rpms for much longer because there will be enough water flow to maintain the lower engine temp. There will be water in the exhaust but it will be less than normal for the rpm. Kind of hard to notice a constricted flow out the exhaust. When the hose lets go you can notice the change in exhaust noise but its easy to miss.A quick fix wold be to remove the hose from the fitting at the elbow and look to see if there is a constriction. This comes from calcium deposits from the raw water against the hot exhaust. If there is, you can usually break it out with a nail, coat hanger etc. See of your engine runs better afterwards. If that fixes it then change the fitting. It is usually a 90 degree threaded hose fitting and can be found at most hardware/plumbing store. It is easier/cheaper than changing the elbow. Sometimes the fitting is so corroded into the elbow that removal is impossible but worth the effort. I carry a spare elbow because it can be changed with a cressant wrench and easier than trying to fool with the elbow in a pinch, But, eventually the elbow will need to be replaced. Really cures you from running the engine at low rpms for extended periods of time. It the problem is on the internal/anti-freeze side of the system then radiator cap, thermostat, back flushing are the normal procedures.Good luckLes Andersens/v Mutual Fun
