You do NOT need to remove the cabinet. There are the bolts on the back of the engine. Remove the bolts then remove the hose from the elbow. If you purchased the exhaust manifold, elbow and connector, then you just need to reassemble the parts and attach the exhaust hose. It may be a good time to replace the exhaust hose too.
