Engine access hatch
Nov 16, 2012
1,055
Have any C310 owners cut an access hatch to the engine from the head? While adjusting the rear motor mounts last week it seemed like something that would make it a lot easier to work on the port side of the engine (starter, alternator, etc.). Because there's so little clearance on that side I don't think it would look bad to have a hole in the wood panel there, but I'm sure I'm not the first person to think of this and value other's thoughts.
May 2, 2012
276
Catalina 310 Toronto, Ontario
The solution for me was to use a 18 x 24 sheet of Acrylic mirror. Works really well and it won't break if you happen to wack it with a tool. I used some velcro to temporarily fasten it to the wall.
Cheers
2 Old Pirates:dancing:
Nov 18, 2010
2,441
Catalina 310 Hingham, MA
I just unscrew the stairs, move them all the way forward and then lay on my side. I did cut in a panel from the back.
