Josh
When I shift in and out of gears with my Yanmar 2QM20, sometimes it takes some messing around with the throttle to get it to engage forward or reverse. This can be extremely nerve-racking on a windy day in the relatively tight fairway of my marina. So far, I've been lowering the throttle almost until the engine cuts, with the thought that the lower the rpms, the more likely it would be to engage. When the engine sounds like it's about to cut, I have to give it more diesel and then try to bring it back down until the prop engages. Sometimes this takes a few tries, and up to 10 secs before I have a responsive prop. I was out yesterday, and had a pretty close call. I've been "dealing" with this issue for quite some time--and by-passed this project for many other projects--but it's time to do something, and even pay an engine guy if needs be. I just wanted to put this out there to see if anybody thinks it's a simple fix, or even minorly complicated. It might be the cables that connect the levers at the pedestal to the engine. Perhaps they just need lubrication? If so, is that a matter of squirting some tri-flow into the connection at the pedestal? Wouldn't it be great if that was it? Anyway, I'm all ears if anybody has any ideas. Thanks,Josh
