Stopped with blades vertical
As Capt Dave noted, most of the time you would want to lock the shaft with the folding blades vertical, but with my new Flex-O-Fold geared prop, I have found both blades will always fold with any kind of slipstream force on them, so that's probably not as necessary as it used to be. Heck, when I installed the thing, it was so well balanced that both blades would go to the folded position in any rotational position with the boat on the hoist!As I no longer race (with my boat), I'm not too concerned with getting the blades in the "perfect" position, I just lock it in reverse after shutting down, and ALWAYS start in neutral as there is never a backload on the gearbox that prevents shifting.Tim
