Hiour 23' Ranger (1976) shows some mini gaps between hull and transom. But it is something that keeps us looking at it as an issue that ahs to be solved soon.After a major complete renovation (2003) we had decided to replace the outboard with a 9.9 4 stroke - did reinforcement inside and a had a special block (plywood) shaped to the best angle to get the motor straight in the water.As we have not found a perfect molding yet to finish that part, we have now seen some movement between hull and transom. Anyone some ideas how to proceed best(procedure and material) - and what is your experience on this particular spot?
