Encapsulated ballast on Passports
1
- - CIRCUMNAVIGATING/PACIFIC
We have a 1989 Passport 40 we have a bulge swelling that is centered under the floor under the navigation table. That area contains encapsulated iron pellets that were added for extra ballast for the Passport 40 line. It appears that this is the area that is lifting the floorboards/swelling the area. We are looking for any information in regards to this problem, how it was resolved etc.
Ross
Jun 15, 2004
14,693
Drill a test hole and see what come up. It sounds
it may be iron rust. If it is some phosphoric acid is in order. That will convert the iron oxide to iron phosphate.
Dec 8, 2007
478
Irwin 41 CC Ketch LaConner WA
Ross:
you are starting to blow my mind. What are you some sort of scyborg with a duel core hard drive implant in your brain. Where do you get all this stuff? *pop
Ross
Jun 15, 2004
14,693
Still raining, It is easy if you learn something
don't forget it! It is a lot of effort to learn don't abandon it .
Dec 8, 2007
478
Very wise counsel
but hard to implement. We are bombarded with information to rapidly.
Ross
Jun 15, 2004
14,693
Pick through it carefully. sort the worth while
from the trivia. For example this is trivia but fun; full moon will occur in about one week. At that time it will be in conjunction with the constellation Orion. It only happens close to the winter solstice.
