Emergency wire cutter (standing rigging)
Gunni
Mar 16, 2010
5,937
Ok, so thanks to everyone for weighing in, but does anyone have name of a decent cutter that will cleanly cut 1/2" on a bouncing deck during a very bad time that doesn't cost a fortune and require a weight lifter physique?
What is definition of "a fortune"? Even with an hydraulic wire cutter you are going to want to wedge the cutter to pump the handle and get the job done. Those little bypass wire cutters won't cut 1/2" standing rig.
http://www.landfallnavigation.com/holmatroewc16h.html
Jul 27, 2011
5,203
Bavaria 38E Alamitos Bay
Do 34' sailboats really have shrouds of 1/2"? I'd think more like 1/4". The Bavaria 38 is has only 10 mm diameter shrouds which is below 1/2" (10/25.4 = 0.39 in), etc.
Check out this thread in SBO.
http://forums.sailboatowners.com/index.php?threads/shroud-stay-diameters-for-h34.149874/
5,203
Perhaps a chat with Poseidon would be helpful here. He might be able to change the fundamental demands of sailboating to accommodate your needs.
Nov 14, 2013
238
Catalina 30 MkI 1983 TRBS Westbrook, CT
I purchased these http://www.amazon.com/Porter-Wire-R...&redirect=true&ref_=oh_aui_detailpage_o04_s00 to install new lifelines. It handled 3/16" fairly well. It is rated to 1/2" but I am not sure it would handle wire that large but as Gambit asks do you really have 1/2" rigging? As for "weight lifter physique"........have you ever used a cable cutter before? Any manual cutter takes a good amount of effort to cut. Cutting the 3/16" I found the best method was to lodge one of the cutter arms against my gut and then use 2 hands to pull the other.
Mar 23, 2009
139
Rafiki 35 North East, MD
Why 1/2"? As far as I know, all of the standing rigging on a Hunter 34 is 1/4" or 9/32".
Jul 4, 2015
436
Hunter 34 Menominee, MI; Sturgeon Bay WI
I figured if I went with 1/2" it would easily slice through the smaller diameter rigging on the 34 in a bad situation (stronger jaws, better mechanical leverage)
Jul 4, 2015
436
Is why I wanted to go with 1/2" cutter
Jul 1, 2010
990
Catalina 350 Port Huron
I don't have cutters, but instead of the PITA split rings, I use a short length of 1/16" stainless welding rod per turnbuckle. Bend it into the right length "C", install it though both halves of the turnbuckle, and bend the ends in so they can't catch the sail. Quick and easy to remove with a pair of needle nose pliers (or a rigging knife). Whether I could easily unscrew the turnbuckles while thrashing around on the waves, who knows. We did lose our mast once on our previous boat, but it didn't go all the way overboard and I was able to gather things up while my wife motored.
Likes: Ilanortho
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
Kloudie can tell you more about them than i can ...from the looks of them they will be easy to use because of the compound jaws
capta
Jun 4, 2009
5,101
Thankfully I've never been dismasted, but have always carried some form of cutting tool, should I need to deal with the problem.
I don't think most realize the urgency of cutting a mast away if it were to go over the side in foul weather, but it could be critical to one's survival to be able to do so quickly and efficiently. Imagine how easily a mast would go through the hull of your boat if the seas were up and it was smashing into the side repeatedly.
I doubt there there is a set of manual cutters that would quickly and easily cut 13mm 1X19 s/s wire, so we carry an electric grinder. I've cut 3/8" bbb chain in well under a minute, so I imagine the wire would go a lot quicker. I can wrap the motor in a plastic bag if things are wet on deck, so that's not a huge concern.
Let's hope none of us ever need to deal with this, but as mentioned above, an ounce of prevention is worth a dozen pounds of cure; check your rigging often! A month back we found an after lower on the main with 3 broken strands at the deck end and we check frequently, so it hadn't been that way long.
Nov 6, 2006
10,247
Woody, I have not used them to cut rigging wire but I did use a friend's to cut a lock hasp to get by a lost key. Worked fine.. Tool quality is not to production shop standards, but in my opinion fine to cover one dismasting.. I don't use them, they stay in a bag with anti rust in there ..
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
if it will cut a shackle of a lock...... then it should be good for cutting ss wire rope
Gunni
Mar 16, 2010
5,937
It is a lot easier to cut chain with a cutter than the same diameter cable. The strands deform and move making the task difficult. It is why I use cable to secure my possessions against theft rather than chain.
Nov 6, 2006
10,247
Note that the ones I posted have both a wire cutter jaw set and a bolt cutter jaw set.
I agree, and have used my Ace Hardware tool to cut 1/4" chain, too. Haven't had to use it on rigging. Didn't cost anywhere near the $110+++ for a "marine" version.
Dec 29, 2008
806
Treworgy 65' LOA Custom Steel Pilothouse Staysail Ketch St. Croix, Virgin Islands
Cordless 4.5" cut-off saw.
Good answer. This was exactly our approach for our recent 12 day offshore passage from Norfolk to the Virgin Islands. We bought 10 extra disks just in case, as they tend to shatter. We also have a wire cutter, but I don't trust it to cut or 1/2" wire rope rigging.
Oh, and watch your fingers...
And arms, and legs...
