Eliminate topping lift
Apr 17, 2013
177
Catalina 310 57 Pompano Beach, FL
I recently bought a new mainsail which is not setup for the dutchman system as the original sail. I was going to eliminate it. During my eliminating process I let the topping lift go and it came out of the mast. Now I will have to go to the top of the mast feed a retriever line down and put in a new topping lift, not much fun. The 310 has a rigid boom vang. My question is do I really need a topping lift, I am a cruiser not a racer.
Thanks,
Mark
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
No........but I like having a topping lift available as a safety line when climbing the mast plus it allows boom adjustment to ensure it clears the arch.
Likes: Skipper John
DaveJ
Apr 2, 2013
506
Agree with both above posts. You can sail without it, many boats do not have one, but there are advantages to having it. I have the Dutchman system, and I use the topping lift to steady the boom when not sailing.
cheers
dj
JRT
Feb 14, 2017
2,060
You could use your spin as a topping lift at the dock
Joe
Jun 1, 2004
8,241
I would consider it a blessing that you will now learn you don't really need a topping lift if you have a rigid vang. Use the main halyard to support the boom, in opposition to the mainsheet, for stabilization when the sail is down. I wrapped my mainsail top lift around the backstay 20 years ago when I installed the rigind vang, thinking it would be there in case it was needed. I have two jib halyards, a spinnaker halyard and a short topping lift for the spin pole. Needless to say, I have never used the old TL since that day.
JBP-PA
Apr 29, 2022
662
Jeanneau Tonic 23 Erie, PA
Another way to rig a makeshift topping lift when not sailing is to use the backstay (if you have one). Use a rolling hitch on the backstay (or a prusik or klemheist as you prefer) to attach a line to hold the boom up.
  • Helpful
Just don’t forget to release it before raising the mainsail! Otherwise the sail will fill and you won’t have any easy way to let the boom off centerline.
Jul 27, 2011
5,134
Bavaria 38E Alamitos Bay
On my boat that line is called a boom lift. As I have a rodkicker rigid vang, I don’t need that line for holding up the boom when the sail is coming down, etc. It has other uses, however. Namely, supporting the boom when using it to lift and move stuff around the boat. Right now I have my RIB suspended along my port quarter from the boom supported by the boom lift. It’s out of the water but can be easily lowered at the stern of the sailboat while in the slip. Sometimes I use it to help me lift the 4-stroke from the deep starboard cockpit locker. On certain days I use it to hoist the flag along the backstay to fly in a virtual the gaff sail position. It can also double as a makeshift main halyard. Having a free line going aloft and over a sheave is a nice feature. I’d get it back up there.;)
Likes: Skipper John
