Hey all,
So a few weeks ago we had an incident with our Raritan Elegance and Electroscan unit, which has been operating flawlessly for 5 years I might add. We started experiencing backflow thru electroscan and toilet into bowl but was discovered before disaster occurred. We immediately started practicing thru hull closure when underway and that worked. I then started investigating our setup and found that my vented loops were not adequate so I modified my plumbing to the following (from intake to discharge)
Hose from intake to pump (with shutoff of course)
Vented loop between pump and bowl (this was already present and I thought sufficient)
Replaced joker valves (2) on the elegance
Added vented loop on discharge between bowl and electroscan (this was not existing before and probably reason for the back flow)
Plumbing from electroscan out as before, electroscan is above waterline at any heal.
So.... My sloppy initial install cost me 3 hours of replumbing but have I accomplished what I needed with this setup? Of course I believe I have but curious what the pros say.
Also I noticed that now when I run bucket of fresh water thru the electrscan (something we do religiously before storing for more than a week) there is a easily audible whistle from the new vent after flush, I'm assuming that is when siphon break happens and the intake is small and now there is far more air... Is this normal? I've tried turning the duckbill valve but sounds the same.
Cheers!
Cheers!
