I'm thinking remove the aft holding tank and install it there. Still leaves the forward head for when a holding tank is required.Thought about installing one years ago but could not figure out where to put it.
Installing it on the most used toilet and leaving a tank on the other one is an excellent choice. However, whether to go with an ElectroScan or PuraSan Raritan PuraSan Promo Sheet depends on whether your toilet uses sea water or onboard pressurized fresh water. If the latter, the PuraSan is a better choice because it doesn't need salt.I'm thinking remove the aft holding tank and install it there. Still leaves the forward head for when a holding tank is required.
Assuming that measures the same height as the port side where the holding tank is, the ES is too tall for the space. The only place I'm been able to identify to install it is in stern lockerSo did anyone end up installing an Electro Scan or Purasan on a Hunter 410? If so, where? I'm looking at installing an Electro Scan in the starboard storage space under the aft cabin berth....
What is the minimum salinty for the Electroscan? I asked a tech at the factory and he said "seawater." Another said anything that does not trigger the low amp warning (but did not hint waht that was). The EPA did a test, but oddly did not mention the minimum salt concentration to meet the certification requirements. Obviously, they make a lot of sense on the Chesapeake because off-shore if so far (the Bay is inside the declamation line, for those who do not know) that many sailors never make it there. NDZs are another topic, but as a practical matter only apply to dockside us and only in a few places.In your waters (upper Chesapeake, which can be very brackish), I'd go with the PuraSan instead because it works equally well in salt, brackish and fresh waters.... Raritan PuraSan Promo Sheet and here's the owners manual for it Raritan PuraSan EX owners manual which includes complete installation instructions. If you plan to do some coastal cruising beyond the Bay, you might consider adding the "Hold 'n' Treat" controls package Raritan HoldnTreat controls that lets you empty your holding tank (which you are gonna keep, right? 'Cuz you will need it occasionally, even in the Bay) through the PuraSan.
--Peggie
The original "salt feed tanks" were 2 gallon "brine" tanks that LectraSan owners made up at home and kept onboard in 1 gal milk jugs. The "brine" solution duplicated average ocean salinity, which is 3-3.5%. To do that you'd need 4 tablespoons of salt (1/4 cup) in 1 gallon of fresh water. Which is the reason Raritan has always recommended that amount when manually adding salt to each flush.
--Peggie
4 tablespoons/gallon is 76 grams in 3785 grams of water, which is about 2.0% salt, or about 57% salinity (I weighed it).
The manual (I'm sure you know this--correct me where I am wrong) for the salt feed system requires a saturated salt solution, or about 5 pounds in 2 gallons. The feed systems adds only a little per flush, so the solution can last through more flushes. Two gallons of seawater would only last about 6 flushes.
To Make Salt Solution: In a separate container, combine five pounds (2.3 kg) of solar salt with two gallons (7.5 L) of warm water and allow to dissolve overnight. Pour water into the tank (this is a saturatedsalt solution). The salt remaining in the bottom of the container may be used the next time.
This concentrated solution is then blended in through a tee fitting, without the benefit of precise regulation. The user is instructed to adjust every 4 flushes, as follows:
How to adjust the salt solution: Open plastic tubing clamp completely. Use toilet and system four times and there should be no low salt indication (LowTreatment reading on the meter for Lectra/San models, Low Salt amber LED for LST/EC models, SlowBlink - Extended Cycle (one blink per second) forLST/MC models and Low Amp reading forElectroscan). See manual for troubleshooting if lowsalt light indication continues. With no low saltindication start closing plastic tubing clamp until low salt indication comes on and open plastic tubing clamp slightly again for optimum salt without low salt indication. Use system four times between each adjustment.
I kinna doubt people check this adjustment every four flushes. Just sayin'. But it is probably not that critical, which was the jist of my question. "How low can salinty be for proper treatment?" The low amp warning will tell you, I'm just curious what that level is and if effectiveness has been tested at that level? I'm surprised the EPA test did not specify, since that is the sort of operating parameter they normally focus on. I suspect they were just thinking "ocean," which obviously completely misses the point (if you have ocean salinity you have good flow and probably no pollution problem--it is estuaries and creeks they should have focused on). A typical EPA "miss".
Yes, I understand salinity. I've built a commercial scale RO desal plant (200,000 GPD). The value you quoted was only 57% of the salinity of seawater. I'm assuming that means the unit can meet standards on 57% salinity and probably a bit less. However, there is no Raritan information or literature giving this value. What is the minimum salinity for proper operation of the Electroscan? This is a simple and important question.Those are the instructions for the current somewhat complex "salt feed tanks" that use rock salt. The instructions I posted are for the old fashioned "brine" tanks that used granulated salt. You can't even find any mention of it in any of Raritan's current literature any more.
As for the "average salinity of sea water," 3-3.5% was the amount in 3 different web articles...and we all know that, if it's on the internet, it must be true.
And as for the EPA, they didn't miss anything 'cuz they don't care what the salinity of a discharge from an ES is, or even whether it uses salt (the ES is the only one that does)...only whether the bacteria count meets the legal standard for discharge from it. Since the legal standard only requires that it be <1,000/100 mltr and the ES and PS reduce it to less than 10, salinity only matters to Raritan and ES owners 'cuz it impacts the life the electrode pack. And it's the USCG, not the EPA, who certifies every Type I and II MSD meets the legal standard. Every new device is submitted in prototype and they test a randomly selected device from inventory every 5 years to maintain certification.
Sea water buildup on the electrode pack will prevent it from treating no matter how high or low the salinity is 'cuz the electrodes can't "sense" it through a crust of minerals. Warm waters have a much higher mineral content than cooler waters, requiring more frequent cleaning than in cooler waters.
--Peggie
That's a question Raritan. You might want to give 'em a call 800-352-5630...and ask for engineering. I doubt tech support will know.What is the minimum salinity for proper operation of the Electroscan? This is a simple and important question.
