Electronics Wiz Required. Autopilot
Aug 5, 2006
121
Hunter 33 brisbane
My low battery alarm on a ST4000 + Raymarine auto pilot continually comes on when the motor is running. I have concluded that it is actually over voltage that is the problem.
Is there an electronic wiz out there who can draw me a circuit to fit a Low Dropout Positive Regulator into the circuit to keep the voltage down to 12 volts. I have a National Semi co doctor LM 1085 3 amp device which re salesman told me will do the job but have no connection diagram.
Feb 6, 1998
11,759
This was a pretty well known failure mode of the ST4000+ series. It is an internal problem and Raymarine no longer services not can repair these heads..
As long as the head is seeing a measured 10V to 15V it is well within its operational range. If you are getting the low bat alarm within this voltage range it is a head failure...
Oct 24, 2010
2,405
Hunter 30 Everett, WA
make sure you check the voltage at the head while it's operating. Corroded connections could be the culprit.
Ken
Apr 14, 2010
195
Jeanneau 42DS Larnaca Marina
Did you put a voltmeter behind the A/P display and the A/P motor to see what voltage they are seeing? Also measure the alternator output when the engine is running. If you really have an over voltage situation, you should be looking at the alternator and it's regulator. It should be putting out about 13.8V. Good luck.
