I am trying to complete/reinstate some charging upgrades started by the previous owner of our yacht. Its hard to tell how far they got because we had to get a contractor to gut the engine compartment, reline, replace seacocks, recondition the engine etc. So the wiring that is there now is what was in place after that work was completed.
The previous owner had installed an Electromaax 140 alternator which is wired through a battery isolator. Output was rubbish at 40amps max. Mounted on the side of the engine compartment but not connected are a Balmar Duocharge and MC-614 regulator. I have connected up the Duocharge and moved the alternator output direct to the house bank. Alternater output now doubled.
OK, long intro over, now trying to wire up the mc-614, but I am a little unsure of the wiring. I have run a sense wire for the mc-614 direct to the house bank. The alternator has a red sense wire connected direct to its positive out post, should this be left in place or disconnected? I am guessing disconnected but after much googling I can't find anything that clearly states this.
Any advice gratefully received before I complete the job.
