Follow Phil and Paul's advice
Dec.26, 2000Dear Bril,Did you see the testing done by the yard? The reason I ask is because if they didn't conduct the test described by Phil they are not going to find the cause of the problem on your boat. If they in fact did do the test I would have to say they missed something given the magnitude of the problem. That means you are going to have to do it yourself or hire an electrician to do it for you. The other thing I find intriguing is the apparantly sporadic nature of the electrolysis, like something is being turned off and on on your boat. We ran into this issue on The Legend and the prospect of laboriously tracing every wire and disconnecting it to find out if it was the culprit was truly daunting, given the amount of wiring on board. In addition, the boat has been completely rewired once and some of the wires were not removed, which only serves to compound the problem. It occured to me that the most likely location for a short would be in the bilge and that was where I started the search. Sure enough a wire to one of our electric bilge pumps had actually worn a hole through its plastic coating and was shorting into the bilge whenever it got wet, which it would do if the bilge pump cycled and water splashed out of the banjo box. Needless to say it was replaced. It occurs to me that you may have a similar problem , but nonetheless you still have to conduct the test described by Phil to find it.In the meantime while you are getting around to it take Paul's advice and wire up and hang a large sacrificial zinc over the side.Fair winds this holiday season.Brian Pickton of BeneteauOwners.netAboard The Legend, Rodney Bay, St. Lucia
