Hello All,
Having an electrical problem, i still have the combi fitted to our Vega but it has been modified to use the Dynastart as a starter motor and an alternator has been fitted.
The problem is i dont seem to be getting any power through to anything, my batteries feed to a 3 way isolator switch which then feeds to the small silver box please forgive the native names for everything im no sparky.
What i am getting - power to the radio/cassette, Nav gear, cb radio, a faint crackle on the vhf but no buttons or lights working, and the ignition light comes on.
What im not getting - No cabin lighting, no power to turn engine over, no bilge pump, basically anything that seems to require a load.
What have i done/tested - Firstly i checked the batteries took them out and fully charged them so i know there ok. i traced and checked the earth to the engine and its intact and ok. I looked inside the silver box and there's no obvious signs of damage, iv'e checked every fuse i can find and all are ok.
Any idea's! to me it seems as if only low voltage equipment is working and not enough power is coming through to feed the items with greater demand, but im no sparky so really i have no idea.
Regards
Scott
Vega 891
Regards
Scott
Vega 891
