Thanks, Capt Jim
I discovered the wires when I ran a 4" hole saw thru the cabin top to install a vent: the bright ends of newly cut copper were barely visible on either side of the hole, so I had to cut away more of the liner to splice in new wire.My mast lights, VHF antenna lead & radar cable all run as you've described, thru the top laminate at the step, then following the main bulkhead/liner joint to the locker outboard of the head. Once I saw that routing, it never occurred to me that may be other wires hidden behind the liner, so I drilled away with carefree abandon. Mistake ! The 'mystery' wires didn't appear to affect any of the lighting circuits, but I didn't check to see if they went to ground (as in a lightning grounding cct.) FYI,the gadgets that are intended for locating studs etc inside walls seem to work to show the presence of wires inside the laminate. Thanks for your comments Jim.
