Do an Electrical analysis
I would suggest performing a comphrensive analysis of what your total electrical system is drawing. Get another person to help you and then place a ampmeter in the circuit for one of your batteries. Disconnect the other two batteries so that you can be sure that you are measuring all of the current.Turn on each light and appliance in turn and record how much current is drawn. Record the battery voltage at the start and recheck it at the end of the session. It should be within 0.1 volts between start and end. VERY IMPORTANT: With everything turned off, do you measure any current? Use a low current scale, 100 mA. The LEDs on your power panel will draw 5-10 mA each, the panel label lights will draw another 10-20 mA each. If these are left on all week, you could have a draw of 1/4A all of the time. Over 5 days (Monday-Friday) this is 30AH. That's a lot of power to light lamps that nobody is looking at. If you have current draw that you can't explain, you need to find out what is the cause. This could involve actually disconnecting appliances that are "turned off".Estimate how many hours each day you use each appliance. Time them if you have to. My refridgerator is my biggest user and it runs about 15-20 minutes/hour *after* it is down to temperature. It runs nearly 100% for 4-5 hours getting down to temp.Multiply the hours/day times the current of each apliance to get your total daily amp-hour requirements. You said that your house batteries were 750 AH total (3x250). According to recommended practices, that means that if you begin recharging when your batteries are discharged 50%, you have used 375 AH. The 85A alternator will probably put out a maximum of 57A of DC current. Most alternators are rated at *peak* currents, not average currents. The DC average of full-wave AC rectified power is about 2/3 of the peak, thus the 57A estimate. I suppose it is possible that your alternator is actually rated at the full DC average vs. peak, but I would be surprised.The math: 375AH / 57A = 6.6 hours of engine running to generate the replacement power. This calculation ignores the taper of the regulator (which is very significent) and the efficency of recharging which is typically 85-90%. The efficiency means that to replace 90AH drawn out of a battery, you must charge 100AH. The taper of the regulator is most apparent after the battery reaches 80% of full charge. Thus you should be able to charge your batteries from 50-80% (30% of capacity) at your near maximum rate. That would be: 750AH x 30% = 225AH / 57A =3.95 hours + 10% more time to allow for the charging efficiency or about 4.4 hours. Not that this is *not* to fully charge, but only to 80% of full.Depending upon your total usage, you may discover that for the hours that you are running your engine, you are not keeping up with your total draw. You may need to modify your usage: Conserve where possible, run your engine longer, or put in a larger alternator. Be aware that a larger alternator will only help to shorten the "bulk" charging time, and not the time to "top-off" the last 20% of the battery capacity. Before I would buy a larger alternator, I would install a good 4-stage regulator on the present alternator. That will give you the best performance and minimize the total time to fully recharge. Also note that it may not be practical to recharge to the 100% level all of the time. You may want to achieve 85-90% weekly and then each month bring the batteries up to 100% and then run an equalizing cycle to maintain the health of your batteries.Two information sources that you may wish to check out are:http://www.yachtsurvey.comhttp://www.4unique.com/batteryThe above sites have great info (IMO) and links to other informative sites.One last opinion. If your 85A alternator isn't keeping your batteries charged, forget solar panels. You would need to cover your boat and the cost per AH of solar power is very high. These are not a good choice to supply large amounts of power. They are good to keep batteries topped-off, and could be considered effective in high sun areas of the world to supply power for a specific requirement.Good Luck.
