Peter J. Brennan
So there we were all set to go on a moonlight sail with guests. Turned on the ignition. Nothing! Not only nothing but the entire electrical system died. No light, no instruments, no fridge, no nothing except anything direct connected to the batteries. Batteries fully charged. Acted as if there were a main curcuit breaker that tripped or a main switch. No circuit breaker and the main rotary switch (1-Both-2-Off) had no effect. Something major cut out between the batteries and the distribution panel. Any thoughts?I am about to go to the boat now and trace what's where. I will report back.By way of prologue, a week ago while coming back to port under power, belts slipping slightly as high-output alternator charged depleted batteries, we suffered a total loss of electrical power. Diesels being diesels, the engine never even hiccupped. The dash ammeter continued to show the battery charging but the battery monitor showed 0 amps. Then everything went back to normal and I thought no more of it, a transient glitch. Had not run the engine since then until I tried to start it yesterday and all went black.
