Electrical switch question
RAD88
Dec 15, 2008
163
Hunter 30 Glen Cove, NY
I should know this but here goes -
I need to install a switch on a 12 v cabin fixture. Should it be DPST or SPST? Or does it matter? My thought is to break the on both the pos. and neg. side. and go with DPST.
Nov 6, 2006
10,218
Most of the time, the switches for fans, lights, etc are Single Pole, Single Throw. (SPST) It doesn't hurt anything to use a switch that would break both pos and neg, but with DC it is not necessary and does no good.
Feb 6, 1998
11,760
The only things broken on both sides on a typical glass sailboat are on the AC circuit like your main breaker that interrupts both hot & neutral.
If this is just a 12V appliance an SPST is all you need unless this is to drive a relay or some secondary electronic wizardry..
Beneteau 323 Annapolis MD
If a DPST is about the same $$ as a SPST, get get double. Wire only the pos to both poles for twice the contacts. This, for when only ONE will go bad, you've got backup.
RichH
Feb 14, 2005
4,773
After my 'last' lightning strike, probably an 'up strike' RF event, up through the boats 'ground', I noticed that where I had 2 applications of DPST switching of hot and ground, those electronic components were the only 'survivors'.
LloydB
Jan 15, 2006
927
Macgregor 22 Silverton
Rich what were those electronic components that were the only 'survivors' of the 'probable' 'up strike' RF event? Were you in the slip or out?
Feb 6, 1998
11,760
In our strike we had numerous items not plugged into anything at all, that were toasted...;)
