Electrical safety ground
Royce
I read an article in the current CW mag about electrical safety grounds for the AC system. I do not have the AC ground connected to the DC ground or rig bonding grid. I did this to prevent setting up currents with my neighbors boat. I have not had any electrolisis problems in the 10 years I've owned the boat. In the article the author advises against this for saftey reasons. He advocates using an isolation transformer, which I agree would be fine if not for the weight and cost of one. He uses an example of an experience in a boat that had the ground connected, but was not making good connection at the plug, and a defective microwave that had a hot to ground short inside. The shell of the microwave thus became live and a slight shock was felt from it. A isolation transformer would have eliminated the problem of a bad connection on the dock plug. I've delt with this problem in another way and was wondering how some of you have delt with it. First, I have gfi outlets in ALL my outlets on the boat. A shorted microwave should trip that. Secondly, if you connected your dc ground, bonding, and ac ground and you have a bad ground connection to shore power and you have a defective onboard device which results in a hot to ground short, you would end up with everything that was bonded becomeing "live". Maybe I'm wrong on this, but thats how I see it happening. Let me know. Royce
