I'm in the process of installing a Link 1000 our 1991 P42 and I have a question. A 2-0 negative cable connects the upper 8D to the lower 8D. Another 2-0 cable leaves the lower 8D, up to a cable race behind the upper 8D and into a white two inch plastic PVC vertical pipe on the starboard side of the engine compartment. This pipe extends below the engine bilge but I cannot figure out where the 2-0 cable goes. I'm assuming this is the main system ground, but where does it connect?I've checked behind the power panel at the nav station, but no 2-0 cable. Is there a negative buss somewhere that it terminates? Perhaps to one of the keel bolts?!Thanks.Terry
