First sail of the season, I inadvertently shut down the engine on my Catalina 28 by the ignition key. Since then, without the key in the ignition, the minute I turn on my batteries the engine alarm begins sounding and the electric fuel pump starts pumping. When I insert the key and proceed through normal engine starting steps, as soon as the engine is running, the alarm ceases and the pump ceases pumping as well. I thought that the ignition switch might be the problem and replaced it this weekend. I still have the original problem. Has anyone else experienced this problem? How did you fix it?
