Electrical Problem with Bilge Pump
A
Andy Klemm
I have lost electrical power to the bilge pump. Would like to rewire. Does anyone have a schematic or advice?
E
Ed Schenck
Bummer!
Could be hard to trace if in a wiring bundle. First, call Hunter and ask for help. Second, check with meter at the float switch which is where the 12 volts should be ALL the time. If no 12 volts there then see if you can find a smaller gauge wire(10 or 12) near the battery terminals or main battery switch. Maybe it just came disconnected. This assumes an H31 always has 12volts to the pump, that it does NOT come from the panel. On my boat(H37C) the wire goes from the float switch through a bundle in the bilge, through the engine bay, and directly to a battery post. The H30 is that way also. Let us know what you find.
A
Aldo Lozano
No breaker, Ed?
I rewired it through a small breaker (red lever) just in case. Salt water make a nice conductor...:)))
E
Ed Schenck
No salt water Aldo.
But I did buy an inline fuse holder that I have yet to install. Thanks for reminding me. In three years, though, that pump has kept the rain water(down the mast) to a low level.
