Hello to all!Okay...here goes! While motoring my sailboat (1977 25ft O'Day with 2002 Honda 8hp 4stroke outboard)I noticed that - if I turn on all instruments (running lights, cabin lights, mast light, radio, & knot meter) the knot meter doesn't work. I checked the battery (brand new Optima Blue D34M) using a volt meter...it registered 13.5v with engine OFF & instruments ON and registered BELOW low with engine ON & instruments ON (testing alternator). I then checked each instrument separately - the knot meter did not work ONLY when the running lights were switched on. So...I followed the wires from the knot meter & then pulled out the intrument panel - the knot meter has two gray wires (that I can see)...one wire goes to the propellor (hull) & the other wire goes to the instrument panel. The wire to the instrument panel is sliced open to reveal three smaller wires (red, green, brown)...the red is attached to the knot meter fuse, the green is attached to the running lights fuse, & the brown is not attached to anything.Everything appeared to work fine last year...??? The only new thing that I did this year was to replace the light in the mast light - it didn't work last year. Help - I am so confused...is it the battery, wiring, alternator, etc???Thanks in advance!Karen
