I am replacing my 21 year old OEM 5 circuit electrical panel and box enclosure with something a little more modern and able to handle the additional circuits I already have or will soon have (GPS, FM Radio, Spreader Lights, Bilge Pump, Cabin Fans, Inverter), and include a way to turn off the 12 volt socket separate from the instruments...
I have found 3 options that will fit in the space requirements I have. I included a picture of a mock layout using option 2 on the new electrical box that I had made (the original one is basically identical, but only 8 inches wide, this one is just over 16 inches wide, once installed you won't know it isn't OEM).
All 3 options will have the separate bilge switch and 12v socket installed as pictured in the lower right.
I am looking for feedback primarily on the choice of panel, but also on the brands themselves, and anything that I may have overlooked.
Option 1 $360 (Defender spring sale price ~$324)
Blue Sea A-Series 13 position Circuit Breaker Panel with Voltmeter and Ammeter
http://www.defender.com/product.jsp?path=-1|328|299263|319684|1506446&id=838196&cartId=2225517
Pros:
-Includes Ammeter (although I feel I do not need)
Cons:
-Most expensive option
Neutral:
-Most circuits (I won't use more than 10 anyway)
Option 2 $320 (Defender spring sale price ~$288)http://www.defender.com/product.jsp?path=-1|328|299263|319684|1506446&id=838196&cartId=2225517
Pros:
Cons:
Neutral:
Blue Sea 6 Position Fused DC Panel with separate Voltmeter
Panel:
http://www.defender.com/product.jsp?path=-1|328|299263|319684|1506449&id=1355726
Voltmeter:
http://www.defender.com/product.jsp?path=-1|328|299263|319684|1506455&id=52494
Pros:
-Availability of Blue Sea suppliers
-Price (and no shipping if I pick up at Defender spring sale)
Cons:
-Addition of separate voltmeter requires the more space than other options
Neutral:
-Waterproof Switches (it's in the cabin)
-Fused (what I have already is fused so I already carry spare fuses)
Option 3 $320 (unknown if Defender spring sale will apply)Panel:
Voltmeter:
Pros:
Cons:
Neutral:
BEP Marine 12 Way Circuit Breaker Panel with Voltmeter
http://www.bepmarine.com/home-mainmenu-8/product-493/902a-12v-12-way-circuit-breaker-panel
Pros:
-Same price as option 2 if sale applies, but smaller footprint
-Breakers not Fuses
Cons:
-Have to special order as it is not stocked anywhere I can find
Pros:
-Breakers not Fuses
Cons:
