Yes
In order; yes, on the bulkhead over the port quarterberth, (obove where it was), yes, not that I found.Who buys mid size sailboats? Middle aged guys. What can't they do? SEE close or far away or crane their arthritic necks, or get down on their knees to try to see the markings on switchs at the floor.I mad up a panel box with a door that swings down providing access to the switches and wiring. I mounted the original panel as well as an additional bank of switches with LED pilots, a volt meter ti indicate state of charge, and a couple of lighter socket outlets. Also wired in about a dozen fuse holders for more sensitive items. Wires run inthe space between the cockpit and the inner wall. VHF and stereo mount above on a swivel arrangement.I thought I had pictures somewhere but can't find them. Easy enough to take more this weekend if you think they'll help.I seem to recall others have done similar work.samlust@verizon.net
